Speedway distributer
rick r
Has anybody in Fordbarn land used the Speedway electronic distributer on 42 to 48 Flatheads. (part # 9108352). If so, what coil did you use? Speedway tech is recommending a 6 V0lt positive ground coil (part # 44740011) Seems strange to me that you would use a 6 volt coil on a 12 volt negative ground system. Please e mail me direct at springgrange@personainternet.com if you can shed some light on my question.
Speedway Motors |
Part # 9108352 > https://www.speedwaymotors.com/Pro-Billet-Aluminum-Distributor-1942-48-Ford-Flat-Head,278699.html
Pro Billet Aluminum Distributor, 1942-48 Ford Flat Head
  • Magnetic trigger style
  • Mechanical advance type
  • Crab/HEI cap style
$136.99 each
In Stock
Was $148.00
Save $11.01
Product Summary
External Ignition Box Required, Crab Cap Type, Red
  • Available for either 2-bolt, 3-bolt, or '49-'53
  • Requires a high energy, electronic control box and coil, like P# 9108223, 44745001
  • Measures 4" from mount surface to the outside of the cap
  • Will not fit some stock fan configurations (may require the use of an electric fan)
  • Extremely accurate Hall effect pickup
Petehoovie
That is not the distributor he was asking about. Notice part number is one digit off.
OP indicates car has been converted to 12 volt negative ground, and probably ignition resistor is gone. Therefore, with the 9108352 distributor, any standard 3 ohm coil could be used. The Bosche blue has a good reputation.
I agree that this distributor will probably not be any better than a properly set-up original.
Notice this type distributor has mounting bolt slots, not mounting holes. Permits unlimited timing adjustments on the car. But that can be difficult on a flathead, which has no timing mark to shoot at. Again, probably be better-off to stay with an original distributor.
Every one I've worked on has needed the timing curve redone to suit the flathead's needs.
Yep. My "37 came to me with a similar distributor by Mallory. I can tweak the timing to get it good running at cruise. Or get it good under hard acceleration. But not both!
