Speedometer parts ?
Don Cape Cod
Is there anyone around who might have a few parts or, yes, a lot of parts? I'm trying to find a round Rochester dial face, no trip type, and a Waltham part. What should be a matching square hole for the square end of the speedo cable ends up being worn round. The gear itself, as the rest of the unit works fine. I just need this item that threads into the back of this oval unit.
Thanks, Don
Don Cape Cod,
Don,
Give Al Lepore (A&L Parts) a call; if he can't help you he may know someone who can help you.
860-693-0112 ( Box 301, Canton, Conn. 06019)
Ron
put grease on the end of speedo cable fill the speedo hole with jb weld then push the square end of the cable in the jb weld and let it set up the grease will let the cable slip out, if nervouse leave the cable end in the jb weld just long enough to set up a little then remove the cable
Hi ford 1, Funny, but I had been contemplating that. I have not put magnifier glass to it yet. Looks kind of smooth inside for JB to grasp. I'll hope to find a part in the meantime as this is not a "hurry up" need
