The wheel gear is like new with
- raised script: "Stewart"
- raised script part #: 11077
- No broken teeth
- raised script: 60T(eeth) 8P(itch)
Furstnow's book on speedometers says this is the right gear for the 30" tires.
The swivel joint turns freely. The treads on the swivel to accept speedometer cable and grease cup cap are in excellent condition. Both halves of the swivel joint have the raise script "Stewart" and "Stewart Made in U.S.A 1802" and the number "12003." The angle bar mounting bracket has the raised part number "4007" (1915 - 1916). Also included is the part number T-17270-A, "Extension Stud Tapered" which screws to the spindle arm through the spindle and rides in front of the axle; "Clamp Block Bolt" part # T-17269-AMB, "Clamp Link & Bar" pt# T-17268-B and "Clamp Block" part # T-17269-A. It's a 2-1/2 to 1 ratio so I assume it's a Model 1913 right hand swivel. Referencing Furstnow's book, I'd date the contraption at somewhere between 1920 to '23 but I could be wrong. The 16 teeth on the fiber pinion gear show some wear.
By the way, you may also need a hub with a raised lip the wheel gear rides against which I don't have to sell. The catalog sell the cables.
Drop me a PM if you're still looking.
