Speedometer Gear Housing Leak
Fillinjc
Hi,
I am puzzled by this one. On my 1930 coupe with oval speedometer I have replaced the missing cable. Last year I installed a gear housing without cable just to seal the drive shaft. I mistakenly bought a housing for a round speedometer. So I have replaced the gear shaft and retainer. Now when driving my grease comes out the bearing end of the gear shaft in the housing opposite the cable attachment. Comes out like soft serve. The bearing diameter of the new shaft (bottom in pic) is actually larger than the old one. No leaks last year. Am I missing some sort of plug in that side of the housing? Seems like I am missing something incredibly basic here.
Thanks,
Jerry
Do you have this plug in your housing? Can't tell from your picture...
If I remember right it is just a dished disc that is a press fit..you could probably make one...
