Speedometer cable
bump2pass
Does anyone sell the 70 inch inter cable anymore or do you have to replace the outer casing and go with the 66 1/2 cable. Thanks allen
Does anyone sell the 70 inch inner cable anymore or do you have to replace the outer casing and go with the 66 1/2 cable. Thanks allen
Allen, if you can not find the length you need maybe get a 'custom' cable made. I have had cables made (not for a Model A tho) by Gene at Flat-o products http://www.flat-o.com/accessories/speedcable.htm He may be able to help you out.
I'm sure there are others that make custom cables if you decide to go that route.
Try Smith and Jones, they have a bunch of cables and can even make custom ones. Good prices and good service.
if you are close to any major city. there should be a speedometer shop that can make a cable for you. In our area it is Northwest Speedometer. in Tacoma
