T tomwhi Junior Member May 2, 2013 #1 sqeeking coming and going. should i remove cable housing then pull out cable and lube with white grease? any idea?
BRENT in 10-uh-C Well-known member May 2, 2013 #3 Yes, just remove cable from sheath and coat with White grease. Reinstall and go have fun!!
Smurkey Senior Member May 2, 2013 #4 Thought mine was the cable and it turned out to be in the speedo head. A little light machine oil on the bushing where the cable "plugs in" quieted things down and remedied the jumpiness of the mph indicator.
