Speedometer Angle Drive
Is there a trick to removing the speedometer angle drive from a Fordomatic transmission? I removed the retaining screw/bolt, but the angle drive won't budge. Once removed, how much ATF will leak out?
I'm preparing to pull the engine & transmission from my 55 Tbird. I've disconnected the speedometer cable from the speedometer and pulled it through the floor and out of the passenger compartment, but it's still attached to the angle drive on the transmission. There isn't sufficient space to remove the cable from the angle drive; for that reason, Gil Baumgartner recommended attaching the cable to the transmission before installing the transmission. I could just leave the cable attached, but I'm concerned that it might get hung up/be in the way while removing the engine and transmission. I've even considered cutting off the cable because a C4 transmission, which uses a different cable, will replace the Fordomatic.
I don't remember any problem removing the angle drive in my 56 but maybe some gentle taps from a hammer will do it. There is noting else holding it in besides the clip. Might try some PB Blaster or similar penetrant
When I put in the C4 in my 56, I had to go with an angle drive because of the space issue. Had it made. One of those unexpected costs.
Did you use the angle drive off the original transmission for the C4 conversion? 57 Tbirds don't use the angle drive, and the 57 speedometer cable and driven gear will work on the C4. When it comes time for the install, I will insert the cable into the C4 before putting the engine and transmission in the car.
I have not yet drained the ATF, but will. How much fluid should I expect to leak out when the angle drive is removed?
Thanks, Paul.
P.S. I still owe you a stamp, but I haven't converted the rear drums to automatic adjusters yet.
You cannot use the 55 angle drive because the trans ends are different as you mentioned. The angle dive I got has the proper trans end for the 57 and up style (gear clipped on). the cable end of the angle drive was the same as the speedo end. Also had to get a custom length cable
Stamp ??
Ya I just changed the speedo gear in my 57, maybe a couple drops, but that was it. I also thought there would be a bunch of fluid running out, but it was just a couple drops off the gear as I pulled it out. Minimal to zero mess.
