AKsportcoupe
My opinion:
Forget the finned bling. Honor the car. Keep it real.
I would consider this pre-war. I used no parts newer than 1942.
Some times the car or truck found behind the barn or out in a field is too far gone or missing too many parts for a proper restoration and I feel it is better to hot rod than to crush. I do agree with of course not chopping cutting or changeing a car in already good restorable shape. Save them anyway we can and build to our liking. I have a 1926 T coupe in remarkable origanale shape and a 1930 A coupe each will be restored stock. But i also have a 1946 ford PU that sat in a field on its side for 40 years. It is not stock, but I can drive across canada tomorrow if I choose.Ha, ha. Now I get you, Brent. You're saying that if people were really into pre-war banger rods they'd only be using the speed equipment available at the time. You are a restorer through and through! That's hard to argue with. I can only say that the new stuff is fun.
From my memory, though, the idea of a pure race car back then wasn't so cut and dried. Guys would drive their cars to a race event, tape or remove their headlights, take off body parts, race around, put everything back and drive home to use their cars to go to work the next day. The idea of the average person having more than one car (or phone, or tv or pair of jeans) came later.
I totally agree that the idea of butchering a perfectly good body style is a crappy idea. As a motorcycle restorer I cringe when anyone chops a perfectly restorable classic bike. Making or approximating period correct modifications is OK, like making a Norton Manx for example.
That's why I don't understand why the hot rod guys are so against fiberglass reproductions. It's a perfectly good basis for a hot rod and is no more "fake" than a metal reproduction. They should embrace repro bodies and parts as a way of maintaining the limited number of originals in an original state.
Awsome car and tis can be done with bolt on parts and change back to bone stock if wanted. But only after all the fun driveing it wears offI like it looks just right.
WOW !!!!I would consider this pre-war. I used no parts newer than 1942.
Try one of these; single carb, but it's 2-barrel. And it's completely bolt-on.my 28 coupe is all stock,would like to add duel carb downdraft intake.will this be a bolt-on or i will have to make some engine up-grades.
Drop in a small block V8, dropped axle, juice brakes, od ******.....
Seriously, the first thing you need to decide is what do you want from your Model A?
This site was designed by it's owner to lean way over to the restoration side and his site HAMB is designed for the modified side.
i have a zepher 2 carb intake,will this work on my stock engine and what carbs to use.
