dick lyons
my 48 has 15 in. wheels. did the speedo and odometer readings change much? I got the coupe this way. I assume it has the original gear. Thanks.
Are you talking about the ring and pinion gear or the turtle gear being original? What is the number on the turtle housing. What are the numbers on the bottom center web of the banjo housing?
Most old speedometers are not very accurate. Most are at least 5-10 percent off. ...My NOS speedo with new cable and sheath is still about five mph off.
