Tom Wesenberg
Try running a ground wire from the condenser ground screw to a good ground on the engine. A good clip lead will do.
Ran it in the dark again... light show is almost gone... only appears at high revolutions and is not nearly as bright as before. Nothing by the coil. One small blue spark between the armored cable and the retard lever, which is almost impossible to see... but it is there. The other part of the light show is at the spark plugs... very faint, but the spark creates an illusion of the spark plugs being transparent.
At any rate... it is still there, so I've still got something not right. I'm done for this weekend... back on it next weekend.
rob
How old are the points? I don't mean how long since you installed them but rather do you know when they were bought new?
I ask because a couple of years ago I remember owners complaining of missing at high RPM and the problem turned out to be week spring holding the points to the cam. as the speed increased the points would no longer ride on the cam and bounce so as not to close each time.
A shot in the dark, I know.
Yes, that's a real good point. However, that wouldn't explain the "light show" he's experiencing.
This is like a "SUSPENSE DRAMA", now we have twiddle our paws for a whole WEEK!
You know, to a Dog
, that's equal to 56 DAYS!
If only Ol' Whatzhis name, (My pet Man) would get that TRAP runnin' maybe I could endure the wait? Buster T.
Wow. Real head scratcher.
OK, a new clue emerged in your last post. You shouldn't see a spark "through" the spark plugs. Since the inside of the plugs is a solid metal conductor, the spark should travel along it and not be illuminating through the ceramic. It sounds like severely corroded plugs now. Since you know how to do conductivity testing, what is the resistance from the top of the plug to the center electrode inside the plug (where the spark jumps while inside the motor)? Should be 0 ohms.
You need to change the plugs. Don't clean them, change them to new. You shouldn't have sparks around the plugs. Not only is it making your engine run bad but in some cases it is dangerous.
Why? Most auto parts keep W16Y or W18Y on the shelf.Dang it... I never wanted to be a drama queen!
It could be an illusion... with the spark travelling along the outside of the insulator... looks kinda cool actually. I'll check the resistance just to see what I've got.
Just bought the points last week... spring seems strong enough.
Yeah, I'd come to the same conclusion... just can't run down to Autozone and pick up a set though... will have to order them.
Back at it next week...
rob
Temperature range. I use the W18Y because they are a bit hotter.hello
what is the differance in the w16y and the w18y and what is best to use
kevin
1930 mo9del a tudor
1923 model t roadster p/u
Try NAPA..................
Paul in CT
