Sparkplug reccommendation offenhauser heads
duane stone
New member
Looking for guidance on the proper spakplug to use on my 59AB with Offenhauser heads, Mallory Ignition, Merc Crank etc. Speedway suggested Champion # 271H10 with 7/16 reach. Do I need a longer reach? I've seen some using an Autolite 437 with 13/16 reach and heat range of 7. WHich one should i use?
I use the Autolite 437's in our Flatheads with Offy heads and Autolite 216's in our stock cast-iron head Flatheads.
I like to use the 1/2 reach power tip plug and counter bore the un used threads witha 45 deg counterbore. I feel this gives beter flame travel. Can't think of the number 12Y something or other.
Also a good idea to check for clearance to the exhaust valve which is under the plug.
