Ok here goes, i wasnt going to get in to this one as i have been there many times over the years....
SPARK PLUGS
Once upon a time i was a much younger mechanic working for a fleet ( Town of Speedway) part of our fleet was a few F600 Ford trucks. At the time they were shipped to us with no bed either v8 FE Big block or 300 six engines. Once recieved we took the trucks to a local company and had dump beds and "in city" rear ends installed in them.
One of the problems we had was they eat spark plugs !! Sometimes needing the plugs changed weekly.....every one of these trucks eat plugs , fouling etc very quickly. Happens to be they used autolite or motorcraft ( later) plugs from the factory.
The champion plug guy came by the shop one day , took one luck at some of these plugs and said " i can fix that these autolite plugs are junk". He gave me a couple sets of champion plugs to try for a while and a hat and jacket. ( the hat and jacket are very important in this story)
The champions ran better and fixed the problem !!!!!!!!
Now as a young mechanic what do you think we said for a long time???? Of course i said the autolites were junk and champions are the way to go!!!!
The champion sales guy was very happy to supply plug for our 100 vehicle fleet, we even started using them in our chainsaws, more jackets , hats and a few shop stools came with the deal!!!!
Years later teaching a four hour class at Lincoln Tech on spark plugs it dawned on me , champion had nothing to do with the fix.
Heres what really happened:
Ford had the correct spark plug in the engine to start with , the correct heat range, the correct extended tip and electrode. We changed all that by changining the rear axle ratio to suit our needs. The rpm band of operation was changed and the engine needed another heat range for proper operation. The champion guy gave us another heat range ( maybe by accident) and we chose champion every after.......
The champion sales guy went on to buying a new dodge, white shoes and white belt as he was very popular for many years.
Many times today i see this story unfold with other plug example, on the flathead we add a cam shaft, change the engine size and install new multiple carbs not to mention gear ratio and tire size with a new exhaust. Does all this need a plug change , you bet it does , then we buy another brand that accidently ( wrong heat range design etc) and guess what thats the brand we use , AND if we can get the free hat, jackets and cabinents thats even better.
Have i ever told ya the story about missing second gear on a medium riser 427 Ford and blowing the engine up at appro 10,000 rpm???? Yep that was caused by STP used on assembly !!!!!!! Yep thats what it was !!!!!!
" Bubba Vision is a terrible thing sometimes"
