While W18's are the closest to 3X, other factors need to be taken into account. A 3X was meant for a stock engine. Many engines today are not stock. A friend has a snyder head on his engine with a Stipe 330 cam. The W16's were pre igniting with crusty white insulators, mileage was good (18mpg) but the engine was not as smooth as we wanted. He thought it was running too lean and changed the carburetor with no difference in performance. A switch to C14's ( modern plug would be W14) gave a smooth idle, tan insulator , smoother power and 19MPG on a long tour. High compression heads have a faster and hotter burn, so a cooler plug just might be what they need.
the following was posted by LArry Brumfield:
HOTTER DOWN TO COLDER - Spark Plugs
For those who may be interested, the following 7/8"-18 spark plugs will fit the Model A and were available as of a few years back. They are also not all the ones that I know of.
Champion (hotter down to colder):
W95D (562)
W89D (589 TT15 )
W16Y (561)
C95F (595)
W20 (520 )
W14 (3076 TT10 )
W10
W85N
W80N
NOTE: Highlighted items were added by me:
5XX are new Champion numbers from local CarQuest.
3076 is Autolite
TTxx are Motocraft
Also the original 3X and W18 which Champion lists as norm. Also according to Champion, the W16Y is hotter than the W18 at low speed but cooler at high speeds over 5500 RPM....(over 5500 RPM? ... maybe Speedy ED J, Pete, George Miller, Dennis Pierce would be interested... maybe even Brent)
Motorcraft (hotter down to colder):
TT15 (the same as Champion W89D)
TT10 (the same as Champion W14)
TT8 (the same as Champion W14)
TT4 (the same as Champion W10)
Autolite:
3076 (the same as Champion W14 and Motorcraft TT10)
Mopar (hotter down to colder):
P-9-7S
P-9-6S
P-9-5S
Prestolite (hotter down to colder)
78-10
78-8
Stitt (hotter down to colder)
137 BSP
197
147 B
13/10
Larry B.
Here is what Vince Falter said about the C16C plugs:
Re: Champion C-16C
Posted by forever4 from 19.65.33.58.broad.xw.sh.dynamic.163data.com.cn (58.33.65.19) on Tuesday, June 02, 2009 at 6:59AM :
In Reply to: Re: Champion C-16C posted by Barry from ? (67.133.62.42) on Monday, June 01, 2009 at 7:19PM :
Yep, My results vary. My experience with many C16C years ago is that they are way too cold and easy to foul and very troublesome.
