k_dodd@swbell.net
When testing Spark Plugs, in my case Champion W16Y, what should the Ohms be? I've got 2 plugs reading fairly high (4.4), and 2 plugs reading fairly low (about 1.7).
The center electrode should have close to zero ohms resistance. If you are measuring any other amount it is probably because of carbon or oxidation at the tip. The spark voltage is about 20,000 volts so the small amount of resistance you are measuring will have no effect.
