Spark plug gap
603Huckster
New member
Sorry if this has been discussed, I ran a search and didn't find anything. The "Ford Model 'A' Instruction Book" states the plugs should be gapped to .027 and Les Andrews says .035. I have found a few mentions in other threads of making sure their plugs were gapped to .035. My question is, why the discrepancy and which is correct?
60 years of Model A’s, gap of .035 never used anything different.
This has been talked about many, many times.
Enjoy.
I agree !! I think that early in 28 the spark plug gap was was .027 . Henry later decided that a wider gap was better . Les is correct .
A sparkler should spark at either setting or anything in between.
The less gap, less chance of high speed misfire
More gap, idle/ low speed will be better
Guten Morgen,
modern spark plugs with for example Iridium electrodes tolerate a significantly larger contact distance.
(I drive the NGK 5 EiX with 0.35 ".)
