No advantage unless compression is changed a bunch. Plug gap goes with engine compression and air fuel ratio...
Bosch blue might make the ignition more efficient but the engine will take whatever it needs for spark.
Ex: A 20,000 volt coil on a flathead might at idle use 5000 volts , the other 15,000 is reserve voltage for hills, lean air fuel ration and normal wear.
