I'm in the process of trying to find the root cause of my spark advance linkage not fitting properly. My linkage is factory standard of 17" inside-inside, or about 17-1/2" total length with the sliding sleeves. The distance from the inside-inside of the control rod arms on the steering column (down) and the distributor plate fully advanced in the distributor slot is 16-3/4" or about 1/4" shorter than the linkage. The linkage was "bowed to fit" before I started this process, as it was causing inconsiency is setting timing, etc. This is on a '29 roadster, with a 7 tooth steering column.
It appears my solutions are: 1.) find the root cause and fix it (preferred option), 2.) bend one of the control arms to fit, 3.) shorten the linkage by cutting and welding, 4.) leave it as is with a "bow" in the linkage.
Has anyone else had this issue and found a root cause that's easy to fix? Or, is their a preferred option of the other ways to jimmy rig it (no offense jimmy)? I'm leaning towards option 2 if I can't find the root cause.
I have checked to see if there is any misalignment of the engine to the frame, but all seems to be well with the motor mounts & rubbers (albeit they're old). I've also checked to see if there is any way to rotate the steering column, but all appears to be rigid.
Thanks in advance if anyone has any guidance or preferred solutions to this problem.
