Source for brass brake cam bushings?
LLCoolT
New member
Hi all,
I recently placed an order for e-brake parts for my 1914 T, only to discover that both Lang's and Snyder's are out of the brass version of the brake cam bushing. Does anyone know another source for these that has them in stock? Or know the dimensions of one so I can turn my own? I could get steel ones, I suppose, but it just seems like brass would be a much more suitable choice.
Thanks.
Hi all,
Thanks.
Any local bearing house, that sell bearings, also has, or can order Brass in anything you want. Herm.
These get very little use. Steel would be fine as long as the cam fit is not too tight. It should not be tight at all and even if it is loose, it is OK.
