M melisa Member Nov 16, 2016 #1 converting 38 ford to hyd. Anyone know of a source for the bent pushrod used to align the clutch to the linkage. Tks Melisa
rg130 Senior Member Nov 16, 2016 #2 If your using a 39 hydraulic clutch/brake pedal assembly with the 38 transmission Bob Drake sales a 39 Clutch Release Shaft Arm which works.
V8COOPMAN Well-known member Nov 16, 2016 #3 melisa said: converting 38 ford to hyd. Anyone know of a source for the bent pushrod used to align the clutch to the linkage. Tks Melisa Click to expand... Not what you really asked for, but this picture may help you see what could make it work. DD
Karl Wolf Well-known member Nov 16, 2016 #5 melisa said: converting 38 ford to hyd. Anyone know of a source for the bent pushrod used to align the clutch to the linkage. Tks Melisa Click to expand... Just an FYI, you want to use -or modify- the arm so that your forces are at 90 degrees to the shaft. This way you won't be pushing things sideways. Karl
