sound deaden material
It's a Model A. If you want to ride in silence, Buy a new Rolls.
I understand its a model A. When my son has to cover his ears becuase its really loud inside and my ears ring after I drive it, I need to do something. My coupe dosnt have any interior panles right now and that is not a priority right now. So this deading material will help out a lot and in the end as well.
I listen to everything Alyssa, my '30 Fordor Town Sedan, tells me. I know when her alternator is charging the batteries by the sound that the fan belt makes. I check the ammeter to confirm, and gently raise the RPM's with the throttle lever to keep the engine from lugging or stalling. When I shift, I listen to the decrease in RPM's so I know exactly when to shift. I don't double clutch when I use this method. I listen to the gears as they make contact so I know how much pressure to put on the shift lever so the gears easily and effortlessly make contact. When I brake, I listen for the shoes touching the drums. I hear a tiny squeak as they make contact with the drums, which helps me determine how much pressure to put on the pedal. When I hear tiny pops in the muffler, I know I need to lean out the air/fuel mixture. I pay attention to all the rattles and squeaks so I know what Alyssa is doing. She talks to me every time I get behind the wheel. I could listen to music on my iPhone while I drive, but that would take away from the connection I have with her. The sound of her ticking valves IS music, and it's one of the most beautiful melodies I've ever heard. :)
Where is all the noise coming from? The engine, transmission, rear end, bearings, torque tube? You may have some problems that need to be addressed.
ODfever I understand what your saying. But when there is nothing but bare metal with no interior panles it gets really loud inside.
I used an insulation pad from MAC's http://www.macsautoparts.com/ford_m...deadener-insulation-pad-cut-to-fit-4-x-8.html under the carpet of my '30 Town Sedan for heat. Claims to be for sound also but I didn't notice any difference because the floor is all I insulated.
I agree with Mark that DynaMat is the way to go. I didn't use it in my Model A because I didn't want to stick it to the floor.
I did use DynaMat in my '55 Ford Ranchwagon and it really does the job.
Yes the Sound deadener works well. Just covering the firewall and inside of the doors and cowl will make a huge difference.
John Poole
I got the insulating material sold by Lebaron Bonney. I got it mainly for heat, but it helped reduce the noise also. I have a coupe and put it under the floor mat, in the cowl behind the panels, and in the doors. I didn't put it on the firewall or above the headliner. It has helped, but I can still hear the car/engine noises.
we sprayed the doors and inside of the firewall down pretty heavily with a smooth finish bed liner, truck runs really quite
John
I used the foil coated foam insulation that comes in rolls that are about 2' in length and the roll is about 6" in diameter from Menards for my A. I wanted to have some insulation for cool weather use and sound reduction. Worked great. I used 3M 777 spray adhesive to attach it.
I actually enjoy the engine sound... but each to their own...
Its not about the engine sound that I am trying to get rid of. Its the noise from the body I dont have any interiour panls in the coupe. I dont have the best ears for sound after getting blowen up in Iraq from IED's. I rather just here the engine sound and not the body plus it dosnet help I have no Shocks.
