Soooo close
BoxCar Tom
Soooo Close. Two car garage, have to walk outside to turn around
I think it is more like a 1.5 car garage the way those two bodies are squeezed together.
How do you get in and out of the car? Align it up as close as you can and push it in and pull it out with a rope????
Same here, when I put my pick up in the pole building I fold the mirror in case the tire would go flat and it would dent the hood on my old truck.
Same 2 car garage with 3 32s about 15 years ago. Yup that's the a 32 frame stuck to the wall. And if you have extra eagle eyes you might recognise the green lamp rescued from the debris of the defunct Edgewater NJ Ford Motor Company Assembly Plant.
461160
Heavy work getting that 32 Frame mounted on the wall?
Nope, actually did it by myself, leaned it against the wall, put a 5 ga bucket under one end, put a bucket under the other end, stepped it up by adding a bucket at each end. Had a makeshift removable bracket to hold it against the wall on the way up. Took a good hour. I needed the floor space.
