I can spend an hour per bore checking for material thickness. You cannot expect your local shop to expend that much time if they are doing it at a flat rate charge. The sonic micrometer checks a very small, specific, area with each reading. Doing a dozen or more measurements in each bore will only reveal a "general" view of the conditions. Do not bother to check the upper areas of the bore (approximately 1 1/2" from deck down) nor the lower 1+" because the casting core has allowed extra thickness in those areas. Be concerned with the remaining areas and if a "thin" section is found look around it more carefully.
