Tom in SW VA
I just purchased a 37 five-window coupe and have a couple of questions:
1. Where should the spare tire be stored in the trunk? I read in the instruction book that the spare is stored behind the front seat (in the trunk) in the three passenger car. There isn't any indication that it is attached with a holddown bracket in the coupe.
2. I filled the tank with gasoline and the gas gauge is now stuck on the "empty" mark. Could the tank float be stuck? Can I get to it from the access plate in the trunk? If so, what can I do to fix it? Has anyone out there had that problem?
3. I live in a state with two license plates. Where can I find a front license holder bracket?
4. What oil is recommended for a 24 stud V-8 engine? (I don't know the year, but is later than the 21-stud 37)
5. Is there an early V-8 group for the 37?
Thanking you in advance..........
