Solution for audio system in model A?
4 4" speakers may have the same membrane area as 1 8", but they usually don't have the same linear stroke.
(Original post deleted):eek:
You're right. The same area requires the same throw to displace the same volume.
There is still no final decision on the speaker set itself. I'm still completely open, but I want to listen to the advice of the car hifi specialist. Www.carhifi-berlin.de takes care of the production of the kick panel and its installation including the loudspeaker.
The plan was to use a two-way system, the large speaker in the side panel under the tank. The tweeters in the corners above the windscreen.
