Patrick L.
I went thru the school of hard knocks concerning electrical connections. We had contracts for plow/salt truck maintenance.
I learned decades ago to cut out crimp connectors. Wires just need to be clean, twisted together correctly, soldered correctly [ enough heat and resin flux] and covered securely. I shrink tube or rubber coat every connection. There are some connectors now are pretty good at all this, but, I still get out the solder gun/iron.
Heck, I'm so anal about this stuff, I do it in household wiring. But, I also hate normal 14 gauge house wire and use 12 instead.
For electrical stuff, resin/rosin core/ flux should be used, not, acid.
When I mean 'cut out crimp connectors' I mean but/splice connectors not ends.
