Hi Curt,
First, thanks to Mr. Endy for his wonderful article.
1. I look at it this way. In our humid area, water causes rust, & water causes swelling. After water evaporates one has shrunk & thinner paper gaskets that could leak with vibration; plus rusty bolts & rusty mating surfaces at the banjo. Just me. After completion, lube will soak into in-sides of compressed paper gaskets to seal same.
2. Not all gaskets manufacturers make them alike, & it appears gasket diameters are sometimes small ........ to adjust or expand diameter, rather than add water, I use a gasket hole cutter & remove a little gasket material off of the in-side of perimeter bolt holes so each individual gasket goes on very "smoothly" prior to any assembly. Messed up bolt holes scraping on bolt threads makes the gaskets thicker at bolt holes with excess gasket material at bolt holes.
3. I measure each "new" gasket & write "measured" thickness on each with a black pencil -- never rely on manufacturer's reported thickness -- foreigners never make the correct U.S. shoe sizes either.
4. If one "trys" a banjo gasket, it gets compressed; ............... hence, I write a "new" compressed thickness on it with a red pencil so I can re-use compressed gaskets ............. believe it or not, gasket thickness gets a little thinner after being compressed just once -- experience shows that twice compressed gaskets does not make much difference.
5. While not having an extra cluster gear yoke to drill & tap to set pre-load in in-lbs, I made a tool with a threaded 4" diameter PVC pipe plug.
6. Cut (3) half circles in the threaded part to fit over your good yoke, remove very top of square top of PVC plug, insert a 1/8" x 1" wide thick diagonal piece of metal to fit in PVC square opening & place same over yoke, i.e., the (3) axles of the yoke, first without cluster gears as recommended.
7. Cut a 1" deep notch through, (i.e., in both sides), of a length of 1/2" PVC pipe, (with pipe longer than axle housing), to fit on the 1/8" x 1" diagonal metal in the PVC plug.
8. Glue a PVC fitting on the opposite end of the PVC pipe that fits a wrench socket.
9. Then turn the PVC plug with an in-lb torque wrench attached to the PVC socket fitting on the end of the PVC 1/2" pipe.
10. Did everything once where pre-loads were accurate with no guess work.
Hope this helps.
