Snyders 6.0 ??
I looked at the prototype last week at Bill Stipes but the new production units have not shipped yet. I too am anxious to get them.
You might check with Bill Stipes. He did a dyno analysis on the 6.0 vs the 5.5 with stock carb and with Weber. I recall the dyno results were pretty rightous.
Tom, If you go to the Snyder's website and look up the new head, it will give you a link to the dyno results. I am ready to buy a Snyder's head but can't decide if the extra money is worth the little HP gain. Anyone have suggestions?
In theory, the horsepower gain is not as important as the net performance, which would be apparent in the throttle response.
Personally, I think it is more of a decision about how your driving style is (gear ratio, elevation, speed, etc.). In the 1400rpm range, I think there is about a 10% increase in Hp and in Torque. Not earth shattering but again, you're only talking about less than 10% increase in compression ratio too over it's 'little brother', ...however I don't remember if that dyno test actually makes a comparison with a stock head but those gains should be much more noticable.
Several other things factor into this IMO. I happen to know there is enough "meat" on the deck to not only raise the compression ratio a tad more, --but also remove some of the recessed area above the piston effectively increasing the quench. Based on what I have physically seen in looking at this head, if someone is willing to do some "blueprinting", there is more performance to be gained.
Greetings Brent,
I received my first 6.0 from Snyders in mid-April...they are shipping! I may have gotten one from the first batch as I had my name in for one for quite some time.
I have not tested it yet.
Dave
