It will be interesting to see what you find. There are almost no high compression heads made for the Model B water pump.
I am only aware of three that were ever made, all in the 1930s and 40s, all cast iron, and all made outside the USA.
Another thing to consider is that this car is in the U.K. and could have the smaller cubic
inch displacement motor in it. If it does you could be lowering the compression by
putting on an aftermarket head. If so you may want to go to a U.S. spec motor.
Does any one know the chamber cc's for the smaller displacement motor?
The small UK (and therefore european) engine has a displacement of 2043 cc and the standard engine ( US and european ) 3285 cc.I read somewhere that the small engine was 2.2L while the US model is 3.3L
Hi,
Im looking at getting a new higher comp head for my newly bought 30 sport coupe. Il need to get the head shipped to the UK.
I see that Snyders to their own branded head but also sell a Thomas head (which is more expensive) I will spend the extra if its worth it.
What are the differences and which would you rate higher?
Im new to all this, so apologies if its been covered before.
Thanks
Iam trying to make the same decision, which head, Snyders 6-1 $325 or Lion 3 $569, I prefer the 6-1 cause it looks better, but would like a 7-1, just wish that new 7-1 cast iron by Tod was out next month cause that would make my decision.
Depending on how the core shop does, it just might be.
Tod
Tod
great news, my mind is made up!
