Sorry Gene, too far to drive.
I looked for a video that would show you how to search for a short with your ohm meter but they are all oriented towards modern cars. So here is a short tutorial by yours truly.
There will be a setting on your multimeter that indicates ohms. If you have a way to set the scale set it on ohms not kilo ohms or mega ohms. If it is automatic just leave it alone.
You may have to change the red wire on your multimeter to the ohm socket. The black wire can just stay in the common socket.
Disconnect the battery. Put a piece of paper between the points. Turn the ignition on.
Touch the two leads together and you will get a reading close to zero, like 0.03 ohms. The reading indicates the inaccuracy in the meter but don't worry, it will not effect the results.
Now put one of the leads on a good ground point on the car. It will be a shinny metal part. If you can, clamp the lead to the ground point because you don't have to move it to do the test. Put the other lead on another shinny metal part to test the ground point. You should get a reading close to 0.1 ohms if there is a good ground at both points.
Now take the other lead and touch it to the end of a wire. If the meter reads OL that means that there is no short in that wire. If it reads a low reading, anything around 0.1 ohms, there is short to ground.
If that wire is OK, then test another wire. If you find a short to ground, start disconnecting the ends of the wire, one end at a time, and re test. When the ohm reading is OL you have found your short.
If you have any questions about any of this, please feel free to write me a personal message (PM).
I will ask that others chime in on their suggestions on how to use your ohm meter. I may have missed something.
