Smelly '36 Woodie needs advice
Timo
My mom passed away and left me the Woodie! How lucky am I?
I'm doing my best to become an "old car buff," but need help with the engine smell. She runs great, but the engine/exhaust is noxious and limits how long I can drive her- the fumes overpower.
What to do? Lead substitute? Engine rebuild?
Also having trouble finding anyone in the Boston area to look at her. Know any garages?
Many thanks for any help or advice.
First thing is to get all of the old fuel burned out of her. Then I would see if I could find some fuel without ethanol. Chanage the oil to get rid of the varnish & junk in it also and add a little MMO to the gas & oil and see if it smells better.
Butch
I'm sorry about the loss of your Mom. She must have thought a lot of you to leave you such a car. You mention engine and exhaust fumes. Can you qualify that a bit?
is it obviously smoking? Is there a gas smell? It could be as simple as getting exhaust leaks fixed up, but a good mechanic as you were saying may be the best bet, if you don't want to really learn the ins and outs of this. I'm taking it that this is a flathead v8?
Thanks,
Bill
Are you getting blow-by out of where you add oil? If so, rings are in order. Just finished this on my 36 woodie.
There are also a lot of noises, drips, smells, and vibrations to get used to with an antique car you don't have with a modern one.
welcome to the 'Barn....hope you can get the car running well, so you can enjoy driving it....got pics??....lol....Mike
Thanks for the quick responses! Someone even wrote info on a potential mechanic. I love the Barn!
Butch-
1. I have run the gas tank dry a couple of times, (gas gauge doesn't work, so I run out sometimes), so "old gas" shouldn't be part of the problem.
2. I will change the oil and see if that helps.
3. I did a Google search on MMO, (I'm a newbie, what can I say?), so I will look for some Marvel Mystery Oil and try that, too.
bk53-
There's no smoke and there's no gas smell. The smell is more like what I imagine carbon monoxide to smell like- fumey, it gives you a headache real quick, exhausty... Not sure how to describe it.
Before I inherited it, it was given a whole new exhaust system and gas tank by a mechanic on Cape Cod, so I don't think there would be holes in the exhaust.
It's a flathead, alright. Original engine, a few newer parts, but mostly original.
mrtexas-
I love this car! I love it's creaks and squeaks and rattles. I am hooked! I am amazed at how durable it is. My only trouble is the smell coming off that engine... It is my only complaint and I just want to fix this one issue.
Any chance of some holes in the floor or missing gaskets around the doors or tailgate? It sounds like you might be sucking exhaust fumes into the car as you drive. Incidentally, Carbon Monoxide is odorless and tasteless. That's why it's so dangerous. It'll get you and you don't know it's around. Good luck and welcome to the 'Barn!
Timo ....................
Check the length of your tail-pipe. Make sure it comes out, at least, to your rear bumper. Someone might have put a too short one on, at some point.
Any muffler shop can weld on an extension.
MIKE :)
It sounds to me like you have an exhaust leak. You need to check out the exhaust manifolds to see if you have a bad gasket. Also, check to see if there are any leaks in the exhaust pipes as they travel through the engine compartment and under the car. If your exhaust system is working properly and in good condition you will not have any exhaust odor in the cab of the car. Also, Mike has a good point, if your exhaust is dumping out under the car that could cause the odor.
On your exhaust... On a station wagon the exhaust should not be run straight out the back, it should be run to the side behind the rear tires, by the ends on the bumper, pointed outward.
The square back of the wagon causes a low pressure area and can suck exhaust into the car, especially if you drive with the rear window open or lift gate up (or the tailgate/lift gate seal leaks). I have a '55 Ford ranchwagon and found this out the hard way.:eek::eek: Hope this helps.
Nice looking Long Roof, enjoy.
Y-Blockhead ,I bet you nailed it right there, a "modern" muffler guy would not know that . 100 bucks says Timo chimes in an says that is it ! ! !
great looking woodie. I hope you get your issues resolved with it. Sounds like you found the right place to ask.
Timo, Beautiful '36! Every time you drive it you'll think of Moms!
I agree to investigate the way the exhaust is routing out the rear of the car. That square back causes a vortex back there. Also agree with the comments on the fumes coming in the gate area. And any junctions in the current exhaust system.
If you could run it up on a rack or over a pit, or even with two wheels (both drivers, or both passengers) up on a tall curb, you might discover some under-car leak (you should hear it). Otherwise work around the rear end of the system. Maybe you can try a bolt-on tip that you can get at any NAPA-type joint to get a few inches of extension.
You didn't say if it's worse when sitting or driving. I wonder if there is any change?
-VT/Jeff
Hi Timo,
on my '32 Tudor, I get a nasty fume smell from the engine breather on the block. If you rule out the exhaust fumes, you may need to seal off the breather and route it to the air cleaner. There are posts on the Barn for doing this. It is the next item on my to-do list.
Cheers, Tom.
Timo, welcome to the world of woodies! Y-Block is right, don't drive with your rear window open, as he correctly says the exhaust fumes will get sucked into your car. I would do all of the above suggestions, change ALL the fluids and see how that helps. Also join the National Woodie Club. Every September there is a woodie gathering in Yarmouth Port on the cape called "Woodies On The Green" It's held the same weekend as Wavecrest, this year I believe it s on Saturday Sept. 21st. Last year there were 29 woodies and it's an easy drive from Boston. Look for info in the woodie times. Woodiewagon46@gmail.com.
36 woodie tailpipe:
picture.php
For the non-woodie owner, 36 woodie has side windows only in the driver and passenger front doors. Rear, back door, and third row openings are for side curtains.
If you are looking for an expert EV8 mechanic, you may want to call Dan Curley in Marlboro MA 508 485 4177. Very knowledgeable and talented mechanic/craftsman who restores vintage race cars, many with flatheads in them.
