smaller tires and wheels
farmerdick
I have 3:54 gears in rear housing 19" wheels and stock 4cyl in 1930. I want to run 16" wheels on front and 17" on rear. What would I expect for rpm`s, steering, engine problems or anything else with this set up. Thanks.
Farmerdick
I`am not sure as yet. Any suggestions would be helpful. Most likely radials. Bias ply would be ok. What do you think?
The aspect ratio of the tire should be taken into account along with rim diameter as both will affect your final gearing. A taller sidewall vs. a shorter sidewall will make a difference.
Whatever you get, I would try to stay as close to the same height as your 19's are.
I saw a TCM movie today - 1943 vintage, with Judy Garland and Micky Rooney. I think it was called "Girl Crazy".
Prominent in the movie was a (11 years old at the time the movie was made) 1932 Ford Phaeton. It was interesting (perhaps I should say, 'odd') to note that the wheels on the '32 (nominally stock 18") were - 21" Ford Steel-Spoked wheels of 1928-'29 !
I think the only "problem" you will have is that it will look funny. Should work just fine otherwise.
At the car show yesterday there were a few A's with smaller than stock wheels and tires. The cars were beautifully done but just didn't look right. I'll stick with the 19's until I put the Cummins diesel in it. (30 coupe)
I'm with updraught, Put the 16" on the back, 17" on the front and find the correct tire height for each. Same caps fit both, can't really tell the difference in the rim size.
I have 16s, handles and brakes much better.
