Small block ID
willowbilly3
I'm dragging home a clapped out 64 Mercury next week to save it from the crusher. I think it's the Fairlane sized one, might be a comet. It has a small block with yellow valve covers. My research came up with a 65 289 being the first yellow valve covers. Is that correct? Could it be a late 64? I just want it for a core to build for a replacement of the 260 in my rpu someday but it would be nice to know what it is.
I bought one like that to use the whole drive-train under a free 60's Baja Bug that was hit in the rear axle. Built up a frame to make a sand dragster out of it then someone made me a good offer and it went out the door.
It would be safer to go by the casting number on the engine block.
This is a link to the top of page 8 of a list of casting numbers. Depending on what you have it might be listed on the bottom of pg 7. The pages are short and easy to read.
http://www.castingnumbers.info/site/browse/m/Ford/p/8
Thanks, good info. Where is the casting number at on the block? I mostly want to make sure I don't make a 300 mile trip for a 221, guess I won't know until I get there.
First double check that the block has five bellhousing bolts and not six. Five bolt blocks used a 3/8-16 bolt while the six bolt blocks used a 7/16-14 bolt. If it has six bolts, it's a later model.
