"slop" in steering wheel
ole_Bill
I have several inches of play in the steering wheel of my '46 sedan. I understand there is an adjustment on the steering box that will take up some of this but it is not obvious to me how I do this. Suggestions?
I once had a 48 ford pickup with this problem and removed one of the shims underneath the end plate of the steering box. It worked! Most of the play was gone.
If I remember correctly, the shim was plastic and very thin. My first impression was,
how can something this thin make a difference, but it did.
make sure tie rods king pins etc, arnt loose wheelbearings also.ck to see box mounting bolts arnt loose.if its all good you may be able to adjust the box but its likely worn out.
