Chris in WNC
thinking outside the box, 1968-style
https://macsmotorcitygarage.com/true-story-ford-flathead-v8-in-a-67-camaro/
To replace the Chevrolet small or big block it came with and use a flathead V8 is amazing.. pull the cheap reliable horsepower and replace it with a crack prone, hot running,lousy power to weight ratio ford boat anchor is a fools errand
So...not a fan of the old Flathead eh?![]()
Not when it irritates the snot out of those nose-in-the-air pompous Chevy guys!!
Here's a 1957 Chevy and Corvette that will make you chuckle![]()
Lots of old cars in Cuba are running around with small diesels from boats and Soviet industrial engines. https://youtu.be/1v3LO6KXoWM
And someone over on the earlier Model A forum had a VW diesel 1.6 from a Rabbit installed in his Model A. The 20 degree "tilt over" of the Rabbit diesel CAN fit under the hood of the Model A.
40mpg in a Model A. Of course right now diesel is half again the price of gasoline.
I didn't replace my 2003 Golf TDI with another diesel for that very reason.
The VW 1.6 diesels WILL burn waste automotive oil. I don't think I would try it in a TDI.
Joe K
