C cars2cool Senior Member Sep 4, 2021 #1 Anybody on here running a sleeved 312? Any problems with over heating since the block was sleeved?
1930artdeco Well-known member Sep 4, 2021 #2 If done right there should be no problems. I am run my Model A on the freeway and all 4 cyl are sleeved with no problems. Mike
C craig Senior Member Sep 4, 2021 #3 As mentioned, if done properly there is no problem and it will be the strongest cylinder in the block. Do them all if you can afford it
Ole Don Well-known member Sep 4, 2021 #4 I have done three over the years. I fit the pistons on the loose side. About .004 to .006. Never had a problem.
C cars2cool Senior Member Sep 4, 2021 #5 1930artdeco said: If done right there should be no problems. I am run my Model A on the freeway and all 4 cyl are sleeved with no problems. Mike Click to expand... How does it do at slow speed and low RPM?
