John Walters Member Sep 3, 2011 #1 Installing splash pans, the holes closest to radiator line up with frame and oil pan, but rear holes are about an inch too wide. Is this common....do you have to bend to fit?
mass A man Well-known member Sep 3, 2011 #2 Sounds like the pans could have been a bit flattened in shipment? Just flex 'em into place, they shouldn't crease on you.
