Slaping noise in engine
pcup
When starting the engine a slapping noise [like a leather belt hitting the wall ] came from the front. I pulled the fan belt, restarted and same noise! Suggestions readily accepted.
Is it the same whether the engine is cold or hot?
My engine also has a noise which I'll probably look into this winter, but I'm sure it's piston slap caused by the rear cylinders being overheated by the cooling chamber being blocked by a lot of rust buildup.
