The speedometer drive gear cover will give you a clue if it is still attached. There are numbers embossed on it that give the ratio. For example 9-37 which would be 4.11 to 1. There is a risk that the cover is not original to the unit so the "best" way to tell is to see what the ratio of the rotation of the axle is compared to the rotation of the drive shaft. Gar Williams
