Customer would like to know if he can run a stock dizzy on his engine. 8ba, .040 over bore, merc 4 " crank and L-100 cam. He wants the external to look as stock as possible on his truck. Thanks Bill
If he's running stock heads that cam is going to be lame, as Ron said, the L100 needs high compression, without it the engine is not nice, the around town torque is not as good as a stock cam. Give it some compression and it will come alive! Really alive! I know I've done it.
You won't get the required compression with milled stock heads, the valves often touch a stock head, so cutting the heads will need the valve area cut deeper, you can see this won't get you very far.
I'm not saying it lightly, low compression + L100 cam is wasting time and money. I've been through the stock cam, drove like a Flathead, then a couple of carbs on top, oooh gota bit more poke up top, then pop the L100 in, eah? Must be a dodgy cam, disappointing, ok up top, bugger all down low. Then pull the stock heads and bung on some Navarro 9.75:1 planks!!!! God damn!!! Really! Holy #@#@ this my friend is a hot rod!!
This is my opinion based on the above experience.
If anybody is running this cam, or a similar spec cam with stock compression, and you think it's good, trust me, put a pair of high compression heads on it and get the ignition optimized, you will be amazed, truly amazed. It nearly made my little brother puke when I first nailed the foot feed.
Martin.
High compression.
The only way.
