The silicone brake fluid I use in my early Ford ruined the original stop light switch. Some one said Harley Davidson has a switch that will go on the master cylinder that holds up to silicone brake fluid. Does anyone know the H-D part number for it?
H D brake light switch #72023-51C made in USA.
I have had two of Ron Francis's swithes fail, so far none of the HD switches have failed? when they failed the silicon got thru the seperation and hydro locked making the switch not work-how do I know this, I drilled on of the switches and fluid ran out, after letting the fluid out the switch worked
Well you make it sound easy to eliminate the brake switch problem but I think silicon brake fluid is well worth the glitch. Try to make a long story short but I know it won't happen. Forty years ago when I had my block garage shop built and I didn't get it properly insulated or heated at first I had a lot of issues with moisture especially during "January thaws". Actually the "46 Ford coupe I had at the time had issues sweating in the damp condensation when high and low temps meet. I had problems with every wheel cylinder sticking in a very short period of time,one time I burnt paint or bubbled it off the wheel itself around wheel stripes before I got back home. Went through a lot of brake line cleaning,reworking cylinders etc. Really didn't know much about silicon brake fluid back then and never used it on the 46 but I did on the next project a '53 F-100.By then in the early eighties some info like in Old Cars Weekly addressed its merits. Just recently the man who bought the '53 from me in 1990 called and asked about the electric fuel pump that went bad. I told him it was probably the ethanol gas that probably ate it up,surprised,shocked actually when he told me the gas in the tank was what I had put in,he never drove or even started the engine. So fuel problem issue is a no brainer.His pole barn was uninsulated or heated truck had other issues it sounds like,rodents etc,what a shame. Finally the moral to my story, brakes he said seems to be fine,nothing stuck as rolled truck outside. Silicon brake fluid I installed in the eighties,not one cylinder (piston) stuck. I doubt if the original type switch works as at that time I wouldn't have had an option. I will accept the once in awhile failure well over a complete brake rework. Again the only failures I have had were a couple original switches and two HD ones.So the moral to this thread's story like others similar is DOT-5 silicone brake fluid sucks and don't use it in your old vehicle. Keep using the lesser DOT spec and change it periodically like you do your other fluids. Got it.
Lonnie
We are going through this same problem ,wheel cylinders were sleeved in stainless new cups but the silicone fluid is leaking past ?? We think to course of a honing pattern .Ted
