Signal Stat 700 wiring diagram
4dy
I have searched the net and found lots of info on other models such as the 600 or 900, but I have a model 700 and need a diagram to wire it up and have the taillights used for lights, brake, and turn signals without adding an extra set of light fixtures. I know I may need to change the sockets out. I have also seen a simple trailer adapter with wire IN/OUT to make all light work.
I don't need a solution for another switch since I have the fronts working with the 700 and just need to get the backlights working. Help!
* * * This is for a 1937, but it ended up in the late V8 section
Is this a 5 wire or a 6 wire switch? If it's a 5 wire switch you cannot use it unless you add extra lights. It has no provision for the stop light circuit.
There are five wires on the Signal-Stat Model 700:
•Green - left front
•Red - right front
•White - left rear
•Black - right rear
•Yellow - flasher
Assuming this is the correct wiring call out for the 700, as stated above there is no brake provision. Don't think you are going to get there with a two filament bulb (believe you are going to need three filaments) short of something else in the circuit.
I wouldn't think it would be too difficult to wire in some diodes so you can use the same bulb filament for turn and brake lights.
I don't mind it the turn signals take completely over for the taillights and brake lights when they are on. Does that help? I don't know why its so complicated, it would seem that when you flip the signal to the left it knows to blink the lights on the left front and back.
If you are handy electrically you can rig up a system using 2 dpdt relays that will do what you want.
But if you were that electrically savvy I guess you wouldn't have asked.
On the face of it, no, you can't do what you want with that switch alone.
Mart.
If you did that, both sides would blink whenever you signaled because they are tied together through the brake lights. That is one of the main functions of a turn signal switch, it is devised to keep that from happening.
The diagram above assumes using the front park lights as indicators. Personally I'd want brighter lights than parking lights for indicators.
It does have it's merits, though.
Mart.
Why don't you buy one of these? I use it on my 36. Works great and is self cancelling by time. It even suspends cancelling when your brakes are on at a stop light. You can use a column mounted turn switch or a micro switch mounted where you want it. I mounted a momentary micro switch on my shifter. IMHO this system is far better than anything else out there on the market. $120 and use your own microswitch.
http://www.turnswitch.com/Turnsignal.htm
My turn signal switch on 36:
Mart.
Here is a diagram without the parking light option.
I included the parking lights in the other diagram as there are some lights that do not have the room to fit a dual contact socket and bulb.
The idea of these schematics is the ability to use a cool looking old time
signal switch and Signal Stat 700 is a neat looking switch, even if it doesn't self cancel.
There are a lot of other good options like the electronic kind if you want to keep the signals pretty much hidden out of sight to not detract from the original appearance of your interior.
Use the turn switch from a 66 or older VW bus. It has all the correct wires and clamps to the stock column. It's vintage looking and almost looks like a Ford accessory.
See if these will help
Mart.
I agree. On the F-series trucks, it's common to press the single contact socket out of the parking light assembly, and press in a new one with dual contacts.
My mechanic finally got the 700 to work but he had to do lots of extra work, new sockets, changed to a 3 prong flasher etc. I should have bought a different model that required much less work. After all that it does look and work well.
