Signal Lights
Ron McIntyre
Does anyone know the company that manufactures signal lights for the pick-up box mounted in the opening of the sloped side?
Thanks
I think one place you can get them is the Be-Bop Chop shop.Pricey but a pretty slick setup.I don't know about nowadays,but it used to be the only thing you will find online about them is their contact info.I've bought a bunch of fiberglass parts from them over the years.They've always been nice to deal with,you will actually talk to the person you will deal with.
Snyder's Catalog PN T-6954
These red lamps are meant to slide into the square portion of the top outer edge of the pickup bed side. you can use these just as parking lamps or as turn signals. You will have to fish your wires through the front square opening of the bed side to feed these lamps. Normally the weight of your wires hanging down in front of the bed side will keep these LED lamps in place so you won't have to glue them into the bed side. The white wire is your ground, black is your power wire. These lamps work on either 6 or 12 volt systems
