Side Water Outlet
v8fordman
Just came across this and was wondering if anyone had ever seen or had one like it? It has Ford script and the diamond cast in it.
The "Diamond" you refer to is the Ford foundry mark. If you look carefully, there is this mark on a lot of the castings made by Ford.
Funniest looking diamond I have ever seen. Looks like a triangle to me.
Arnold, I agree that it is a triangle and an original foundry mark.
Original Ford Model A cylinder heads manufactured during production had either a straight line, 45 degree line, or a triangle on the top of the head between the two upper water pump mounting studs. This foundry mark was used for QA (Quality Assurance) to identify the source of discrepant parts.
Cylinder heads manufactured later and sold at Ford dealers as replacement parts were marked differently.
