Side pan/Shock Question
Hi everyone,
I'm going to be putting side pans back on my tudor which must have been removed at some point after it was restored in the 80s because 4 of the 6 bolts are on the frame. I'm having a set of shocks found and rebuilt by Robert Paul; should be done within the month-ish as he has cores for them, but upon reading up on the side pans, some posts saying it adds a little rigidity to the front, would it risk the tabs breaking quicker to have them installed on a car that doesn't have shocks at this time?
In short should I wait to put the pans on once I'm installing shocks or go ahead and install the pans now?
Thanks!
I would not worry about putting the pans on now, I don't think lake of shocks for a while would be an issue.
I agree with Phil.
I don't rigidly install the pans. It isn't right/correct, but, I make thin rubber insulators/pads to go between the pans and the frame and engine. The tabs on the engine tend to crack and I think the rubber helps a bit.
But, whatever you decide, it'll turn out fine.
