Relvis P. Johnson
Switching from Nu-rex back to standard Distributor, the points ground out when closed. Do I switch the coil wires? Will that burn out another new ammeter?
You really should start with a schematic. Without one, you're just guessing. Notice that the points are supposed to short to ground. That completes the circuit through the ignition switch, which energizes the coil. Tracing this circuit can answer a lot of questions.
I printed this out and laminated it. It's in my car at all times.
Hope it helps!
Is the red wire in the drawing on the + or - side of the coil, or doesn't it make a difference? The drawing doesn't show. Afordman31
Question regarding 1930 wiring change to include the ignition circuit thru the amp meter. Do you just. Move the black wire from the yellow side of the junction box, to the yellow/black side, which now puts it on the output side of the amp meter? If so, then the laminated wiring diagram from mafca, is wrong, as it's note says "drivers side of COIL" that would change polarity??
At the end of 1929 the coil feed wire (black) was moved to the other side in order to show coil current while cranking the engine. BUT, at the side time the coil primary terminals switch sides in reguard to polarity. There is a picture and description in the service bulletins.
I moved my black wire to the other terminal box post on my 1928 in order to see the coil draw while cranking. It's always best to do a coil polarity check to be sure.
The Chicagoland MG club has an excellent short read on coil polarity and is easily found by doing a Google search for "coil polarity".
So are you saying the original coil polarity was wrong.?
Steve: if you read toms post #9, he is moving both coil wires and the black to the other side of the junction box.
