roadster36
Whoever told you that is correct. They are not used on hot metal and they don't shrink by beating little dents into the panel. I have had to fix quite a few panels after "experts" beat the hell out of panels with the shrinking hammers only to make the problems much worse. Also, like Rotor said, when you hammer the metal against metal you are going to get the metal to stretch, making the problems worse. A small amount of heat, going slowly will achieve the best result. I have also tried the shrinking discs and they also work but I have not really mastered it.
