JM 35 Sedan
I'm not ready to take the car on a road trip. I rebuilt the distributor and I think that's doing fine. I checked voltages after I was done...getting 6.17 volts to the upstream portion of the resistor and 2.7 at the coil. I just received my new resistor...if that's not the problem, I have a nice spare. If it's not the resistor, I guess the only other problem might be the coil dragging it down...if they can do that. The script coil has likely never been rebuilt so it could be due. Will need to build some trust in the car before I travel to a meet another state away. I'll trailer it until then. I'll be gone for 3 weeks starting july 2nd so I think I'll miss that meet but will try to make it to others.
Kerk, I would not leave my driveway without having a Skip Haney rewound coil on my car. I am using a stock helmet type distributor on my '35 fordor. I also carry an extra rewound coil in my spare parts. The insulation used on the windings in these coils, 70 to 80 years ago, is definitely inferior to the modern wire insulations used today. These old original coils may work fine when you initially start up and drive off, but as they heat up, turns in the coil may start to short due to internal expansion and leave you sitting on the side of the road until they cool down. Some folks mistake this for vapor lock.
If you can't make the Brainerd, Minnesota meet this year, please consider coming to our RG's Gettysberg meet in August, 2016. I would love to see that car!!
