No. When you are trying to get maximum compression, why do something that
decreases compression.Two flat mating surfaces are the minimum area attainable.
Also, the flame front travels faster over a flat surface rather than one with
humps, valleys and corners..
So to confirm what you are saying, Pete. Your thoughts on an ideal chamber is a flattop piston that does not extend past the deck surface and a corresponding flat chamber in the head?
Pete >>>When you are trying to get maximum compression, why do something that
decreases compression.>>>
I'm confused. How does a flat popup that kisses a correponding flat recess reduce compression?
Pete,
How much "squish" do you aim for when you run the flattop set-up?
Tim
pete,
how much "squish" do you aim for when you run the flattop set-up?
Tim
As this is the "Mother of all Threads" on the subject of reliefs. Here is a "stepped" relief that I did on my own "experimental" 284 cubic inch engine that is in my 32 Cabriolet.
I did this to mimic some of the Harkey KR race jugs that I happen to have. I've used this engine to try some different ideas, concepts and parts out on.
It has a big-*** roller cam (huge duration and .420 lift), coatings on pistons, valves, cometic MLS head gaskets, etc..
A guy needs to have a flathead "playground" to have some fun in. LOL
You give up a LOT of intake port area with those old raised surface blocks.
I have never heard of anyone machining the raised surface off before porting. Have you??
Hey Pete - I have not either, but I can't see there being an issue doing so. What I have not tested (with a sonic tester) is there any difference in the amount of material below the raised intake surface? Interesting thing to ponder!
