PeteVS
I'm putting a '48 rear into a '32. I've got the torque tube shortened and now I have to shorten a '34 driveshaft (with a 10 to 6 coupler) to fit. I assembled a seal and bearing into the tube, inserted the driveshaft and then put in the thrust washer, speedo gear, and snap ring. With the speedo gear centered in the opening for the igloo, there's about 3/16" that it can slide back before it hits the thrust washer. Is that too much play? Is it a problem if the speedo gear can slide forward a bit? (By the way, what's the groove in the back end of the speedo gear for?) Thanks!!
