41panelmark
Went out to start it yesterday and the battery was dead as a doornail. This was odd since it has been starting and running fine for over a year. The starter and gen are in good shape as is the regulator. No lites were left on. After recharging the battery I pulled the cap off of the regulator and checked for voltage at the Armature, Field and Battery poles. All showed power. This may be correct since I am running a positive 6 volt system. All ground straps are new and connections are clean. The battery when connected shows 6.40 Volts and when disconnected it shows 6.60. So I have a small drain some place.
Any thoughts?
Thanks guys.
Any thoughts?
Thanks guys.
